Shdsl bundle links
May 1st, 2008
I have about 8 G.shdsl modems. each link has 2Mbps.i can not use MLPPP case all the links terminated on G.shdl module (not serial link) or can not CEF cause my link are 8 not 6!
any other solution?
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Thu, 05/01/2008 - 08:09
Actually with modern IOS, you can configure up to 16 parallel static paths, and CEF will use them all.
Documentation referring to a maximum of 6 paths is obsolete and does not apply.
