05-01-2008 03:48 AM - edited 03-03-2019 09:46 PM
Hai, Let me know if cisco 2600 series WIC can be used in Cisco C3845-IPBASE-M router.
it is urgent.. plz.
Solved! Go to Solution.
05-01-2008 04:55 AM
05-01-2008 03:52 AM
It depends on what kind of WIC it is. Please confirm.
Martin
05-01-2008 03:57 AM
Sorry Martin, cross-post. I'll leave this one with you :-)
Jon
05-01-2008 04:35 AM
Hardware is PowerQUICC MPC860
05-01-2008 03:56 AM
Is there a paricular WIC you are interested in - can you send the part number.
Jon
05-01-2008 04:30 AM
Hardware is PowerQUICC Serial
05-01-2008 04:32 AM
05-01-2008 04:38 AM
I believe this may just be a componant of the card you are refering to. If you look at the front of the card where this interface / interfaces are in the top corner you should have a Cisco part code such as WIC-1T, or WIC-1B-S/T.
Martin
05-01-2008 04:46 AM
Hai Martin,
yes it is WIC-1T..
A.Chenthilkumar
05-01-2008 04:55 AM
Your WIC-1T is supported in the 3845 ISR.
Martin
