May 1st, 2008
Dear friends
I have two bar from 4 wire SHDSL HWIC card on my 3845 router. I have IAM on each HWIC to achive more bandwidth. I want to know is possible to bonding these two SHDSL HWic and use IAM on them to reach more bandwidth?
Paolo Bevilacqua Thu, 05/01/2008 - 06:04
Hi, I think that with "IAM" you mean ATM IMA.
However, the shdsl hwic does not support ATM IMA.
miskoolak Thu, 05/01/2008 - 07:06
Acctully we can have IAM ATM on HWIC for SHDSL for bonding 4 pair or 4 line to about 10 Mbps..
Paolo Bevilacqua Thu, 05/01/2008 - 07:26
Hi, once again, that is spelled "ATM IMA (Inverse Multiplex Access)".
Now if you could provide a link that states that ATM IMA is supported on the the SHDSL HWIC, I will be glad to correct myslef in saying that it is not supported.
