Upgrading from CCM 5.1 to 6.1?
Answered Question
May 1st, 2008
Is there anything special that needs to be done for upgrading from CallManager 5.1 to 6.1? Any type of reconfiguration that will be required, or any data that will not be carried over?
From what I've been able to gather from the documentation, it's really just a straight upgrade, like applying a patch to CallManager 5, just wanted to make sure there's nothing we're missing.
Overall Rating: 4.5 (2 ratings)
Jaime Valencia Thu, 05/01/2008 - 08:35
  • Cisco Employee,
  • Hall of Fame,
    2011
it is really straightforward as you mention, just verify the compatibility to make sure all is fine:
Cisco Unified Communications Manager Server Support Matrix
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Table 4 Supported Cisco Unified Communications Manager Upgrades for Release 5.x and Release 6.x
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp1268956
javalenc
if this helps, please rate
Correct Answer
Rob Huffman Thu, 05/01/2008 - 09:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
