Swich 3550 -24-emi Help please
May 1st, 2008
I have a 3550 which doesn`t bring up the int fasthernet interfaces in a "sh ip int brief"command or "sh Run". The system LEDlight stays amber and rps also but not flashing? I haven`t got a rps connected could this be the reason ?
If i do a "sh env all" command everything seems ok
[Switch#sh env all
FAN is OK
TEMPERATURE is OK
POWER is OK
RPS is NOT PRESENT] could some one maybe exlpain ??I would thankfull!
Switch#sh post
Stored system POST messages:
POST: CPU Buffer Tests : Begin
POST: CPU Buffer Tests : End, Status Passed
POST: CPU Interface Tests : Begin
POST: CPU Interface Tests : End, Status Passed
POST: Switch Core Tests : Begin
POST: Switch Core Tests : End, Status Passed
POST: CPU Interface 2nd Stage Tests : Begin
POST: CPU Interface 2nd Stage Tests : End, Status Passed
POST: CAM Subsystem Tests : Begin
POST: CAM Subsystem Tests : End, Status Passed
POST: Ethernet Controller Tests : Begin
Failed data line test (2).
addr=0x00000,sent=0x80000 recv=0x00
POST: Ethernet Controller Tests : End, Status Passed
!!! WARNING: The switch is not usable !!!
Switch#
Sushil Kumar Katre Thu, 05/01/2008 - 09:00
  • Gold, 750 points or more
Hi Jacob,
This could be a hadrdware failure and you'll have to get this switch replaced.
-> Sushil
