Dynamic VPN on Cisco 7609
May 1st, 2008
Dear all,
I am trying to implement Dynamic VPN on a Cisco 7609 (IOS 12.2<18>SXF13) & when I connect to this router through a Cisco VPN Client, an IPSEC tunnel is established.
When I issue "sh crypto ipsec sa" encrypted & decrypted packets are not equal & Split tunneling is also not working properly. Is anyone facing similar issue on this platform as same testing is working fine on low end series routers.
Any help in this regard would be appreciable.
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group TEST
key test123
pool LOCAL
acl SPLIT
crypto isakmp profile TESTPROFILE
match identity group TEST
client authentication list USERAUTH
isakmp authorization list USERAUTH
client configuration address respond
crypto ipsec transform-set CISCO esp-3des esp-sha-hmac
crypto dynamic-map DYNAMIC 10
set transform-set CISCO
set isakmp-profile TESTPROFILE
reverse-route
crypto map TESTVPN 10 ipsec-isakmp dynamic DYNAMIC
ip local pool LOCAL 172.16.1.1 172.16.1.254
ip access-list extended SPLIT
permit ip 172.16.0.0 0.0.255.255 any
permit ip 192.168.0.0 0.0.255.255 any
Akhtar
mchin345 Wed, 05/07/2008 - 12:47
Both encrypted ( to be decrypted ) and unencrypted( to be encrypted ) packets will be sent to the VPN module . and the sum of these two is equal to the packets out figure
