Possible to Ping but not Trace
May 1st, 2008
Im troubleshooting an issue within my network.
I can ping a destination within my router
but I can not trace to it.
My trace just fails along the path
I was under the impression that
both trace and ping use ICMP packets?
Overall Rating: 4 (1 ratings)
mheusing Thu, 05/01/2008 - 07:14
Just an additional comment: Cisco routers will use UDP packets for the traceroute. Only the "TTL expired in transit" answer is ICMP. You can see this from an extended traceroute:
Protocol [ip]:
Target IP address:
Source address:
Numeric display [n]:
Timeout in seconds [3]:
Probe count [3]:
Minimum Time to Live [1]:
Maximum Time to Live [30]:
Port Number [33434]: <-------- UDP port 33434
Loose, Strict, Record, Timestamp, Verbose[none]:
Tracing the route to
The first packet will be sent to UDP port 33434 and each subsequent packet will have the UDP port number increased by one (33435, 33436, ...). In case your traceroute starts from a router, do not block those UDP packets and also allow the ICMP TTL expired packets in return, as described in the previous post.
Hope this helps! Please use the rating system.
Regards, Martin
