IPV6 Traffic
Istvan_Rabai Thu, 05/01/2008 - 18:09
Hi Ali,
Without seeing your config it is difficult to say what might the problem be, but I have one guess:
In the frame-relay map statements you should configure the link-local addresses of the neighbor routers, not the normal ipv6 addresses, like this:
frame-relay map ipv6 FE80::1 103 broadcast
You can find the autoconfigured link-local address of the serial interface of the neighbor router by using the "show ipv6 interface brief" command on the neighbor router.
You should apply this link-local address in the frame-relay mapping on the local router.
If this doesn't solve your issue, then please post your config.
