Startup and Running Out-Of-Sync Summary
Answered Question
May 1st, 2008
I have a lot of out of sync. is there any way to know who change the config
Correct Answer by Joe Clarke about 8 years 8 months ago
There is a bug where Common Services Discovery will not properly resolve IPs to hostnames. This only affects CS 3.1.1 (i.e. LMS 3.0.1). A fix is forthcoming with LMS 3.1 in June. In the meantime, you would have to add local hosts entries for your devices, or manually add the hostname to DCR.
Overall Rating: 5 (2 ratings)
Joe Clarke Thu, 05/01/2008 - 10:23
Sure. Look at the ChangeAudit records. Go to RME > Reports > Report Generator, and run a ChangeAudit standard report for the device and date range you want. Specify the Application as All, the type as CONFIG_CHANGE, the mode as All, and the username as All. That should show you all config change records for that device.
eliaspaulos Thu, 05/01/2008 - 11:24
Thank you so much, I have quick question..CW can find any new device by Ip address on topology servces. but not the device name.I'm always
adding the device name manually on CM. is that
the right way. or on Device and credential able to detect the device name.
Correct Answer
Joe Clarke Thu, 05/01/2008 - 11:28
