Beginners question on AAA
May 1st, 2008
folks
i'm trying to get my head around some AAA concepts and i'm finding the documentation a bit confusing as it doesn't explain some of the core concepts (well not simply enough for me!)
if i define the line
aaa authentication login ConsoleIn local
i know that loca will refer to the local database but where is the group ConsoleIn referred to in the config
is it in the con0 config where i would declare
aaa authentication ConsoleIn
if so, does this not mean anyone declared in the local dbase is not entitled to console access
thanks to anyone taking the time to reply
Richard Burts Thu, 05/01/2008 - 12:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Michael
You have it just about right. If you configure:
you are creating a named method (where ConsoleIn is the name) and it will authenticate attempts to login using the locally configured userIDs and password.
The name must be used somewhere in the config to indicate what is using this method. The name suggests that it would be configured under line con 0 to specify authentication on the console. But it logically could be configured under line vty 0 4.
And yes it does mean that someone who is not in the local database in not entitled to console access.
Rick
mulhollandm Thu, 05/01/2008 - 12:14
rick
many thanks for your reply, its greatly appreciated - i have my snd exam tomorrow so i'm doing some late cramming!
can i ask another question if you don't mind
if i declare 4 names in the local database and i point the ConsoleIn method to this, is there any way to restrict console access to only 2 of the 4 declared usernames?
apologies if this sounds naive but ....
Richard Burts Fri, 05/02/2008 - 05:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Michael
I am not aware of any way that you can restrict access to the console to only some of the configured local userIDs.
Good luck on the SND exam.
Rick
mulhollandm Sat, 05/03/2008 - 04:16
rick
many thanks for your help
i passed the snd (1000/1000!)
Richard Burts Sat, 05/03/2008 - 08:34
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Michael
Congratulations on passing the SND test.
Rick
