Password Recovery on PIX 515E and Configuration
May 1st, 2008
I'm going to use this procedure, but I didn't see If this procedure keep my current configuration or delete it ?
Do you know something about it ?
jsoudah Thu, 05/01/2008 - 11:06
It will keep the config and just delete the passwords.
lveraza Thu, 05/01/2008 - 11:11
There is a way that I can see the IOS version that I have there, in PIX ?.
I didn't find any old configuration.
Jon Marshall Thu, 05/01/2008 - 11:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
"sh version" will show you the pix version eg from one of your pix firewalls
LabProtect1# sh ver
Cisco PIX Firewall Version 6.3(5) <---- this is the bit you want
Cisco PIX Device Manager Version 3.0(1)
Compiled on Thu 04-Aug-05 21:40 by morlee
LabProtect1 up 70 days 11 hours
Hardware: PIX-515E, 32 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: ethernet0: address is 000e.84e6.c447, irq 10
1: ethernet1: address is 000e.84e6.c448, irq 11
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Physical Interfaces: 3
Maximum Interfaces: 5
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has a Restricted (R) license.
Jon
lveraza Thu, 05/01/2008 - 12:01
I know, but I don't have access to this PIX, for using the recovery password procedure, I need to know the IOS version.
jsoudah Thu, 05/01/2008 - 12:22
You don't need to be in enable mode to do a show version if that's what you mean. You will need to be connected to the console to do the password recovery as you probably know.
Patrick Laidlaw Thu, 05/01/2008 - 13:24
  • Gold, 750 points or more
If you reboot/power off your Firewall and connected into the console it will show you what version it boots. From there you will be able to select the correct file for uploading to the PIX.
You all need to understand that when you're doing a password recovery that you're NOT deleting the configuration. You're simply going around the conventional method of loading it so that you may modify its settings. The setting you're concerned with during the recovery is the password. So, you'll change the password and reload the firewall. This will load up the configuration with your password modification.
Again, you're not removing the startup config, just modifying it with regards to the password.
