05-01-2008 11:52 AM - edited 07-03-2021 03:48 PM
I have installed an UC500 wich has 2 wireless VLAN in order to manage data and voice traffic separately.
Now I need to extend the wireless range to cover all the office through a 1131AG AP. As I read in the docs, a repeater AP supports only the native VLAN and cannot configure multiple VLANs on a repeater access point.
Is there any other way to extend both VLANs through an AP? What about 2 APs? I'm a bit lost and need some advise.
Solved! Go to Solution.
05-01-2008 10:36 PM
The best case would be to connect your 1131AG with an ethernet connection. If you can't get a cable at the point that you want to install your access point then it is impossible to support 2 vlans (ssids) with repeater access point. Using 2 APs as you mentioned would work.
But in general, repeater mode is not recommended because it reduces your available bandwidth to half.
Just try to get a cable to the place that you want to install the AP.
05-01-2008 10:36 PM
