Upgrading CCM,CER, Unity
Answered Question
May 1st, 2008
Hi, I was wondering how everyone keeps their versions up to date on their voip applications. Is there a site that Cisco has where I can find out what I should be running for Callmanager, CER, BARS,Unity, and IPCC? I have been put in charge of keeping these up to date but have no idea where to start. Thanks in advance.
Correct Answer by Rob Huffman about 8 years 10 months ago
Hi Efrain,
Hope all is well my friend. Good question! This can become very complicated very quickly especially when it comes to inter-operability and compatabilty between these products. You don't want to get too far behind in versioning but you don't want to be "bleeding edge" either. This is probably the best Cisco doc, especially for these types of questions, that I have ever seen;
Cisco Unified Communications Manager Software Compatibility Matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp1576951
Have a look at the various sections and you will see what the latest and greatest versions are, and what works with and has been tested with each other piece of the puzzle. You have to be careful and really plan these out because Hardware comes into play with many upgrades as well. As I said this can be come complicated but not overwhelming if properly planned out :)
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Thu, 05/01/2008 - 13:40
Hi Efrain,
Hope this helps!
Rob
Jaime Valencia Thu, 05/01/2008 - 21:09
along with the great info that Rob provided also be very careful to look at the UCC compatibility which can be tricky
Cisco Unified Contact Center Express
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_device_support_tables_list.html
Cisco Unified Contact Center Enterprise
http://www.cisco.com/en/US/products/sw/custcosw/ps1844/products_device_support_tables_list.html
Unity would be the least of the worries because as long as you have the right TSP version it will work with CUCM.
for CER you need to choose first the CUCM to then review the compatibility.
javalenc
if this helps, please rate
