05-01-2008 09:06 PM - edited 03-10-2019 04:05 AM
I am working with the IDSM-2, We have Cisco 6509 with CSM & FWSM, We are planning IDSM-2 in Inline mode and now i want to monitor the traffic which is coming through Outside Interface of the FW context ( Which is nothing but a VLAN A, VLAN B, Vlan C. on MSFC )
Data flow :-- ISP RTR---INternal RTR---FWSM---IDSM---MSFC---CSM---
IDSM version is 5.1(4)S257.0,
This will support only Two VLAN (IN and OUT) on access mode.
My problem is I don't know how to scan the traffic of 3 numbers of VLAN (A,B,C).
Cisco 6509 --- Version 12.2(18)SXF7,
Solved! Go to Solution.
05-02-2008 01:33 AM
You can use inline VLAN pair mode to monitor traffic coming on specific VLANS. For eg
You have VLAN 100,200 and 300 on MSFC that you intend to monitor inline.
You need to configure VLAN 101,201 and 301 (L2 only) and send VLAN 100-101,200-201,300-301 to IDSM-2.
You then need to create VLAN pairs on IDSM-2 module as below
1 - VLAN 100-101 - pair 1
2 - VLAN 200-201 - pair 2
3 - VLAN 300-301 - pair 3
Then assign above three pairs to Virtual sensor and it will monitor this traffic for inline operation.
Inline VLAN pair mode is based on VLANs, so it doesnt really matter whether VLANS are behind or front of FWSM.
Cheers,
Vinod
05-03-2008 11:15 PM
You need to configure 3 inline vlan pairs . Suppose you are interested in monitoring vlan A, B , C and your MSFC is in vlan D. You need to configure 3 vlan pair such as
vlan A ,D
Vlan B, D
vlan C, D
You can refer the below link for coniguring inline vlan pair
http://www.cisco.com/en/US/docs/security/ips/6.0/configuration/guide/cli/cliIDSM2.html#wp1067639
Hope it helps
05-02-2008 01:33 AM
Cheers,
Vinod
05-03-2008 11:15 PM
vlan A ,D
Vlan B, D
vlan C, D
Hope it helps
05-05-2008 07:27 AM
Hi.
I dont think you can use the same VLAN ID in multiple pairs. You cannot use VLAN D as per the above example in all the pairs.
You might need to create dummy L2 vlans for everyvlan that you want to monitor. Move the IP address from the actual VLAN interface to the newly created vlan interface.
e.g. If you have
interface vlan A
ip address A.A.A.A .......
You will have to create a VLAN X.
vlan x
interface vlan x
Now use the IDSM to configure pairing between A and X
IDSM will simply bridge the two vlans together.
HTH.
05-06-2008 04:22 AM
As mentioned my front end is FWSM--MSFC--, so i don't have any ip address assigned on that vlan it is just a L2 vlan, so now what ?
One more thing, which I want to clarify, is that VLAN Pair configuration provides the Hardware bypass.
05-06-2008 05:05 AM
your dummy vlan (for every fwsm vlan) will be the actual end user vlan. (switchport access vlan command).
IDSM-2 will just bridge the dummy vlan with the actual vlan in pair.
Vinod
05-06-2008 08:17 PM
Vinod,
My actual VLAN 10 and i created one more dummy VALN 101, so do I need to change the FWSM configuration also like
From
firewall module 1 vlan-group 1,2,3
firewall vlan-group 2 10 100
To
firewall vlan-group 2 101 100
so the data flow is just like VLAN10--IDSM2---VLAN 101--FWSM--MSFC
and
correct me if i am wrong, VLAN pair configuration is not available with IDSM-5, i think we need to upgrade the IDSM 5 to 6 and what about Hardware bypass? is hardware bypass is available with VLAN pair?
Please provide me the link for any configuration document of VLAN pair with IDSM-5
Dinesh
05-06-2008 11:12 PM
The link for IDSM running 5.1 which has provision for inline vlan pair http://www.cisco.com/en/US/docs/security/ips/5.1/configuration/guide/cli/cliguide.html
Udaya
05-07-2008 12:43 AM
Hi Udaya,
I am not able to find out any subinterface.
I think it is available from IPS 5.1 and this one is IPS5.0(2)
IDSM2CORE2(config-int)# show settin
physical-interfaces (min: 0, max: 999999999, current: 3)
media-type: backplane
description:
admin-state: enabled
duplex: auto
speed: auto
alt-tcp-reset-interface
none
description:
duplex: auto
speed: auto
interface-name: System0/1
description:
duplex: auto
speed: auto
command-control: GigabitEthernet0/2
inline-interfaces (min: 0, max: 999999999, current: 0)
bypass-mode: auto
interface-notifications
missed-percentage-threshold: 0 percent
notification-interval: 30 seconds
idle-interface-delay: 30 seconds
05-07-2008 02:11 AM
Your FWSM configuration will not change and will remain as it is.
FWSM configuration
MSFC Configuration
Vlan 101
intrusion-detection module "slot-number" data-port "1/2" trunk allowed-vlan 10,101.
IDSM-2 configuration
Login to GUI and go to interface configuration --> VLAN pairs
Click Add.
Interface name - gigabitethernet0/7 or 0/8 (this corresponds to data port 1 or 2)
Subinterface number - 1
VLAN A - 101
VLAN B - 10
Give a description and click Apply
Next go to analysis engine - virtual sensors
select the pair you created above and click on apply. (This creates the inline vlan pair and bridges the 2 vlans).
Try generating some attacks from end user vlan (101) and see idsm-2 blocking attacks.
goodwills
Vinod
05-08-2008 08:23 PM
Hi Vinoth,
Ur posts are helpful for me to understand the Inline VLAN pair deployment.So then how to send log to the destination, where my IEV is installed in one of the Vlan in FWSM. Kindly provide me the config steps also..
05-08-2008 09:28 PM
IDSM-2 logs are sent using the management interface gig0/2. Depending on your management VLAN (either on FWSM or MSFC) where your IDSM-2 is placed, you might need to do the configuration accordingly.
Vinod
05-09-2008 12:14 AM
Hi Vino,
Thanks.Let say my Managent Vlan is in FWSM(VLAN 120). I need to monitor Vlan's 100, 160, 130, 140. So if that is the case..Kindly provide me configuration steps for sending logs to Mgmt Vlan 120.
07-24-2008 10:38 PM
I am done with the config (Inline VLAN PAIR), but i am not able to see any logs at event viewver.
I enabled all FTP & MSN signatur but there is not logs for the same and able to access the internet services.
any one can help me out to trouble shoot the problem ?
Regards.
05-04-2008 08:40 PM
Thanks Vinod and Uchimaku, i am planning for the installation at production environment, hope you guys will be available in case of any problem.
Thank you,
