How to configure vpn remote access in cisco877 router
May 1st, 2008
HI fellow networkers,
I have a cisco877 router that needs to be configured as a VPN server, normal
traffic will be from a remote client to LAN behind cisco877 router. The set-up
looks like this:
LAN-->cisco877 router-->Internet(via DSL)-->remote client
The remote client can already get inside the LAN, and we need to configure
remote-access VPN, wherein my router should run as a vpn server. Please refer below for the initial config of my router:
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description Outside Interface
ip address 10.10.10.1 255.255.255.252
ip virtual-reassembly
ip tcp adjust-mss 1436
no snmp trap link-status
pvc 8/35
encapsulation aal5snap
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description Inside Interface
ip address 192. 168.1.1 255.255255.240
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.2
One of the requirement is to enable three remote host from different locations to access a local server located in my LAN. What configuration items should we do
and can you provide refrence on how to configure this set-up. Thank you very much for those who will reply.
brgds, emman
emmanuel_s Sun, 05/04/2008 - 17:13
Hi Andrew,
I have already looked in this software guide..but I need to check and find the
appropriate solution to configure a remote access VPN.
Currently, I installed SDM in my PC and now
I can successfully modify my 877 router's configs. I have configured a remote-access VPN using Cisco Easy VPN.
My question now is how/what VPN solution to apply if the remote PC is a database client
accessing a database server behind 877 router.
Since Cisco VPN Client is not free, are there any solutions available withour using this software?
Thanks in advance for the reply!
