Combine flash memory
Answered Question
May 2nd, 2008
Anyone who can help me find the command to combine my 2x32mb flash to have a single 64MB flash memory so I could upload an IOS larger than 32MB?
Thanks!
Correct Answer by Paolo Bevilacqua about 8 years 10 months ago
You're welcome, please rate useful posts with the scrollbox below.
Overall Rating: 5 (1 ratings)
cisco_lad2004 Fri, 05/02/2008 - 03:59
  • Gold, 750 points or more
format bootflash: or format flash depending on what u have.
Sam
Pravin Phadte Fri, 05/02/2008 - 06:32
  • Silver, 250 points or more
I am not sure how format would help. As i went through a cisco documnet which says partition can work for integrating 2 flash.
Partitions Flash memory.
Router(config)# partition flash partitions [size1 size2]
Partitions Flash memory on the Cisco 1600 and 3600 series.
Router(config)# partition flash-filesystem: [number-of-partitions] [partition-size]
http://www.cisco.com/en/US/docs/ios/12_2/configfun/configuration/guide/fcf009_ps1835_TSD_Products_Configuration_Guide_Chapter.html#wp1001191
let us know if it helps.
cisco_lad2004 Fri, 05/02/2008 - 06:39
U are absolutely correct, it is partition and not format.
It has been a long time since I used it on my 2500. and it definitely works as it shouls.
apologies for the hasty reply !
Sam
mbserrano Sun, 05/04/2008 - 18:41
Hello Guys, im not sure if i got you there. here's my problem: I have an on board flash which is 32MB and i have a compact flash at 32MB also. i want to install an IOS which is around 36MB so i need flash size of more than 32MB. how can i combine the two 32MBs so i could have a single 64MB?, well if it is possible.
MArlon
Paolo Bevilacqua Sun, 05/04/2008 - 21:22
  • Hall of Fame,
    Founding Member
No, you can't do that. Get a bigger compact flash.
Correct Answer
Paolo Bevilacqua Sun, 05/04/2008 - 22:08
  • Hall of Fame,
    Founding Member
