Problem with Static and Dynamic NAT on ASA5510
May 2nd, 2008
i am using ASA5510 for my network.i have configured static and Dynamic NAT.static NAt working fine.Dynamic NAT pool have a 10 public Ip Addresses.but inside users cannot able to access internet.
Port map Translation failed.
but this dynamic NAT changed to PAT .its working.
Please help me to configure Dynamic NAT
S.Mohana sundaram
srue Fri, 05/02/2008 - 18:25
can you post your nat and global commands that you have configured please. is the dynamic nat pool in the same network range as the IP address of your outside interface of the ASA?
smohanasundaram Fri, 05/02/2008 - 18:56
Hi global pool same as outside Ip range
my puplic ip is x.x.x.0/27
the above subnet have 30 Ip's active the range is x.x.x.1 to x.x.x.30,x.x.x.31 is broadcast.
global (outside) 1 x.x.x.15-x.x.x.29
nat (inside) 1
static (DMZ,outside) x.x.x.4 netmask
static (DMZ,outside) x.x.x.5 netmask
static (DMZ,outside) x.x.x.6 netmask
static (DMZ,outside) x.x.x.7 netmask
static (DMZ,outside) x.x.x.8 netmask
S.Mohana sundaram
srue Mon, 05/05/2008 - 05:16
with this configuration, what is the output of "show xlate".
also, have you tried something like:
global (outside) 1 x.x.x.15-x.x.x.28
global (outside) 1 x.x.x.29
