intervlan multicast
May 2nd, 2008
hi.
i'm having trouble setting up intervlan multicasting on a catalyst 4510R.
multicast within the same vlan works fine but after putting the source in a separate vlan i cannot get it to work.
ip multicast-routing is enabled
and ip pim sparse-mode is set on the vlans in question
i have tried dense-mode, adding an RP address. pretty much everything
i'm sure i've missed something simple as it doesn't seem that difficult a thing to set up!
could someone help me with the config?
thanks.
Overall Rating: 5 (2 ratings)
Harold Ritter Fri, 05/02/2008 - 03:26
  • Cisco Employee,
Mike,
A very common problem is that the source transmits using a TTL of 1, which will work if the source and the receiver are on a common subnet but won't if they are separated by one or more router.
mikedelafield Fri, 05/02/2008 - 05:08
good call on that one!! spot on
ttl was indeed set to 1.
ended up using ip pim sparse-mode and setting the RP-Address manually
thanks
