ISDN
May 2nd, 2008
Dear all,
for fire the ISDN
isdn test call interface PRIint remoteisdnno this isdn Command
Some other router using
isdn call int PRINo Remote ISDN no
please tell me why this differance
guruprasadr Fri, 05/02/2008 - 03:23
  • Gold, 750 points or more
HI, [Pls Rate if HELPS]
To make an ISDN data call, use the isdn test call interface command in privileged EXEC mode.
isdn test call interface interface-number dialing-string [speed 56 | 64]
Note:FYI
dialing-string
>>Telephone number used for making ISDN data call.
speed 56 / speed 64
>>Line speed (56 or 64 kbps) used for making ISDN data call.
Default:
The default B-channel speed is 64 kbps.
How to Use:
You can use the isdn test call interface command to test your DDR configuration. You can also use this command to verify the dialing string and speed without having to know the IP address of the remote router or without configuring a dialer map or string.
The isdn test call interface command replaces the isdn call interface command.
Examples:
The following example makes an ISDN data call through interface bri 0 to 555-1111 and at a line speed of 56 kbps:
isdn test call interface bri 0 5551111 speed 56
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
