Debug IP Packet Output
May 2nd, 2008
Hi Guys, Can anyone interpret what these messages mean or point me to a place where i can get the interpretation:
IP: tableid=0, s=192.168.36.6 (local), d=192.168.36.254 (Vlan36), routed via RIB
IP: s=192.168.36.6 (local), d=192.168.36.254 (Vlan36), len 77, output feature, Check hwidb(63), rtype 1, forus FALSE, sendself FALSE, mtu 0
IP: s=192.168.36.6 (local), d=192.168.36.254 (Vlan36), len 313, output feature, Check hwidb(63), rtype 1, forus FALSE, sendself FALSE, mtu 0
The full message is attached below
O.
mchin345 Thu, 05/08/2008 - 06:10
  • Silver, 250 points or more
1) Test another cable that you know it works instead of the one you have attached to the port.
2) Make sure the Speed and the Duplex configuration are the same in both points.
I think it does not affect the operation of the switch
o.osunkiyesi@np... Thu, 05/08/2008 - 06:14
The interfaces that I am getting those messages form are actually conected to a 100Mb ethernet leased lines
