Broadcasting certain SSID's on AP's
Answered Question
May 2nd, 2008
I have a large campus network. We have about 15 AP's at a Library which are connected to their own vlan and trunked back to our main admin building, which is where the WLC is located. We also have about 5 more AP's located in different buildings. My question is, how do you only broadcast an SSID that is local to its location? I don't want the ssid "library" being broad casted anywhere i have an AP.
Correct Answer by Rob Huffman about 8 years 10 months ago
Hi Michael,
Really a good question, and probably one that we have all had to think about at one time or another.The feature you are looking for is called WLAN Override :)
Enabling WLAN Override
By default, access points transmit all defined WLANs on the controller. However, you can use the WLAN Override option to select which WLANs are transmitted and which ones are not on a per access point basis. For example, you can use WLAN override to control where in the network the guest WLAN is transmitted or you can use it to disable a specific WLAN in a certain area of the network.
From this doc;
http://www.cisco.com/en/US/docs/wireless/controller/4.0/configuration/guide/c40wlan.html#wp1114777
Once you create a new WLAN, the WLAN > Edit page for the new WLAN appears. In this page you can define various parameters specific to this WLAN including General Policies, RADIUS Servers, Security Policies, and 802.1x Parameters.
**Check Admin Status under General Policies to enable the WLAN. If you want the AP to broadcast the SSID in its beacon frames, check Broadcast SSID.
Note: You can configure up to sixteen WLANs on the controller. The Cisco WLAN Solution can control up to sixteen WLANs for Lightweight APs. Each WLAN has a separate WLAN ID (1 through 16), a separate WLAN SSID (WLAN name), and can be assigned unique security policies. Lightweight APs broadcast all active Cisco WLAN Solution WLAN SSIDs and enforce the policies that you define for each WLAN.
From this good doc;
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080665d18.shtml#c3
The most popular way to mitigate the problem of having to access each AP individually (when using WLAN Override) is to use WCS Templates for common requirement AP's. This way the WLAN Override function can be applied at the Template level and then pushed out to the various groups.
http://www.cisco.com/en/US/docs/wireless/wcs/4.0/configuration/guide/wcstemp.html#wp1072198
Hope this helps!
Rob
Overall Rating: 5 (3 ratings)
Correct Answer
Rob Huffman Fri, 05/02/2008 - 05:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Michael,
From this doc;
From this good doc;
Hope this helps!
Rob
pmccubbin Wed, 07/23/2008 - 13:44
  • Silver, 250 points or more
Rob,
Thank you!
Best,
Paul
Rob Huffman Thu, 07/24/2008 - 08:28
  • Hall of Fame,
    Founding Member
Hey Paul/James,
Thanks very much guys! Much appreciated :)
Rock On!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
