Boot 3650 from TFTP
May 2nd, 2008
How can I set the switch so that it loads the startup-config file from a TFTP server. The goal is when switches are moved between locations, they will get thier config info from the local TFTP server (same IP in each location).
Sushil Kumar Katre Fri, 05/02/2008 - 07:54
  • Gold, 750 points or more
Router1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router1(config)#service config
Router1(config)#boot network tftp Network-auto 172.25.1.1
Router1(config)#boot host tftp Routers-auto 172.25.1.1
Router1(config)#end
Router1#
You need to have Network-auto and Routers-auto files [wheere you would have the configuration]in the TFTP server.
-> Sushil
