Save Log on database
May 2nd, 2008
I'd like to know if is possible to save automatically the ASA's logs on a database like MSSQL.
If not, what are the other options?
Patrick Laidlaw Fri, 05/02/2008 - 16:42
I do not know of a way to directly send the logging information as a MS SQL query or put the data directly in to a SQL database. I would imagine the easiest way is to find a program that take the syslog data or snmp trap data sent from the ASA and import it from there into a database.
