autocommand not working
May 2nd, 2008
Trying to configure a user to be able to login via ssh and only see the router's configs. Router in question is a 2801 running IOS Version 12.4(15)T1.
Using local username database, no aaa new-model.
VTYs configured as follows:
line vty 0 4
login local
transport input ssh
User configured like so:
username dummy priv 15 secret 0 XXXXXXX
username dummy noescape autocommand sh run
When dummy logs in, no config is shown and he gets privileged exec mode prompt.
Jim Moore
Overall Rating: 5 (5 ratings)
moore_j58 Fri, 05/30/2008 - 04:57
Not what I"m after. I want the automatic command to be invoked only for a specific user, not for anyone connecting to a particular line. Furthermore, with my configuration and IOS combination, neither works:
config 1:
username dummy priv 15 secret 0 dummy1
line vty 0 4
login local
autocommand show running-config
transport input ssh
config 2:
username dummy autocommand show running-config
line vty 0 4
login local
transport input ssh
In either case, when dummy logs in he gets the
privileged exec command prompt, no running configuration display, and no automatic logout.
When I change the input transport to telnet, both work.
moore_j58 Wed, 06/18/2008 - 09:43
Yes, I got the following answer from Mauricio Oviedo of TAC:
After reading the problem description included in your SR, I understand that
you are having issues setting automatic commands for SSH sessions.
The bug CSCdz17608 causes this problem on the Router. Here are the details:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fet
chBugDetails&bugId=CSCdz17608
When user logs into the router using ssh, autocommand is not executed when
using "login local" as in following config:
username autocommand
line vty 0 4
login local
transport ssh
Workaround:
Configure aaa instead of using login local.
Example:
aaa new-model
aaa authentication login VTYS local
aaa authorization exec VTYS local
line vty 0 4
login authentication VTYS
Please let me know how would you like me to proceed with this case and feel
free to contact me if you have any question or doubt.
Best regards,
Mauricio Oviedo
SMB Team
Cisco Support Engineer
Email: moviedo@cisco.com
Phone: 407 241-2965 x4682
Monday through Friday 8:00 a.m. - 5:00 p.m. CDT
I verified that the fix works.
pmccubbin Wed, 06/18/2008 - 11:33
Hi James,
Thanks for posting the fix. I rate it a "5" and hope you continue to follow up like this as it helps everyone who uses the forum.
Best,
Paul
