UNABLE TO INJECT A STATIC DEFAULT ROUTE FROM PE????
May 2nd, 2008
Description:
I am unable to get a static default route via MPBGP session for a vrf, any other route redistributed the same way is getting through.
Just the static default route isn't ????
1>
SOURCE PE WHERE IS THE ROUTE REDISTRIBUTED:
pe1#
router bgp 4755
bgp router-id 10.10.10.103
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor 10.10.10.100 remote-as 4755
neighbor 10.10.10.100 update-source Loopback0
address-family vpnv4
neighbor 10.10.10.100 activate
neighbor 10.10.10.100 send-community extended
exit-address-family
address-family ipv4 vrf B
redistribute static <<<<<<<<<<<<<< STATIC REDIS
no auto-summary
no synchronization
exit-address-family
address-family ipv4 vrf A
no auto-summary
no synchronization
exit-address-family
ip classless
ip route vrf A 0.0.0.0 0.0.0.0 Serial1/0 192.168.1.2 global <<<< STATIC ROUTE POINTING THE GLOBAL CONTEXT INTERFACE
ip route vrf B 0.0.0.0 0.0.0.0 Serial1/0 192.168.1.2 global <<<< STATIC ROUTE POINTING THE GLOBAL CONTEXT INTERFACE
DESTINATION PE HERE I CANNOT SEE THE STATIC DEFAULT ROUTE:
pe3(config-router-af)#do sh ip bgp vpnv4 all
BGP table version is 11, local router ID is 10.10.10.103
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 4755:1 (default for vrf A)
*>i172.16.1.0/30 10.10.10.101 0 100 0 ?
*>i172.16.2.0/30 10.10.10.102 0 100 0 ?
*>i172.16.10.0/24 10.10.10.101 2297856 100 0 ?
*>i172.16.20.0/24 10.10.10.102 2297856 100 0 ?
*>i172.16.200.0/24 10.10.10.102 2170112 100 0 ?
Route Distinguisher: 4755:2 (default for vrf B)
THE STAITC ROUTE IS REDISTRIBUTED TO LOCAL VRF CONTXT ASWELL AS WE CAN SEE:
pe3(config-router-af)#do sh ip route vrf A
Routing Table: A
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.1.2 to network 0.0.0.0
172.16.0.0/16 is variably subnetted, 5 subnets, 2 masks
B 172.16.200.0/24 [200/2170112] via 10.10.10.102, 00:00:23
B 172.16.20.0/24 [200/2297856] via 10.10.10.102, 00:00:23
B 172.16.10.0/24 [200/2297856] via 10.10.10.101, 00:00:23
B 172.16.1.0/30 [200/0] via 10.10.10.101, 00:00:23
B 172.16.2.0/30 [200/0] via 10.10.10.102, 00:00:23
S* 0.0.0.0/0 [1/0] via 192.168.1.2, Serial1/0
Hope I am clear in explaining the issue...
Dara
Overall Rating: 5 (1 ratings)
jander2008 Fri, 05/02/2008 - 07:55
Hi:
"Unfortunately" you HAVE to use the default-information originate cmd with BGP in addition to the static route.
Same goes for Ospf.....
A simple default static will not get redistributed !!
Regards.
dara111983 Fri, 05/02/2008 - 08:34
Hehehe :)
"Unfortunately" that's true !!!!
This could have been the last thing that I try.
Getting he techs work, protocols work is fine.
But if get to make myself understand the logic behind adding this command as well than ... :(
Thanks a lot,
