VoIP over dsl based VPN
Answered Question
May 2nd, 2008
I have an office on our network that is moving to a dsl connection. There are three users in this office. They will VPN into the network. How do I set up a VPN to provide them with VoIP? It is a court so they should keep the same numbers.
I currently have a 3550 switch at the far end. Do I need a router? Comes back into an ASA.
We have a very small pipe to the internet.
Long term solution is for a DSL hub.
Correct Answer by paolo bevilacqua about 9 years 2 months ago
Best is to use a config example from CCO, there are many.
There is no real need to separate voice and data vlan in small sites, it works just fine even if you don't do that.
Overall Rating: 4 (1 ratings)
paolo bevilacqua Fri, 05/02/2008 - 08:57
  • Hall of Fame,
    Founding Member
Hi, yes you need a router in the branch. As small as an 857 or 877 can do. The difference is that the 857 doesn't support QoS, VLAN and other features, beside that will work fine.
paolo bevilacqua Fri, 05/02/2008 - 09:41
  • Hall of Fame,
    Founding Member
Hola,
When you have ADSL, 877 is the best choice.
Usually is a good idea to get 877w so you also have wireless using a single device.
If you never configured a router <-> ASA VPN before, reserve some time to learn and and try the configurations.
Consuelo.Annon Fri, 05/02/2008 - 09:47
I was just going to ask you for recommendations for config.
All our current vpn users are client based. This would completely different.
All natted through firewall.
I fI set up 5 of these sites can I use the same voip and data vlans on all of them?
Correct Answer
paolo bevilacqua Fri, 05/02/2008 - 09:53
  • Hall of Fame,
    Founding Member
Consuelo.Annon Wed, 06/11/2008 - 13:47
FYI
I ran into an issue requesting a static ip for the VPN from Qwest. They assigned it to the mac-address of their netopia router and wouldn't tell me that nor will they assign a static to a Customer device.So I could not get the DSL to come up. Took off the Static and hope it stays up.
Made me appreciate the customer service I et Cisco!!!
