Callmanager service not starting
May 2nd, 2008
Hi All,
I installed the CCM 4.1(3) on a MCS 7812I2. The OS version is 2000.4.4. The Callmanager service refuses to start.
Does anyone have any insight that might help? The service was already activated within the CallManager and I was able to use it before. This issue popped up yesterday afternoon. Thanks in advance.
By the way,
Today I installed the win-OS-Upgrade-K9.2000-4-4a-sr12.
Jaime Valencia Fri, 05/02/2008 - 12:15
  • Cisco Employee,
  • Hall of Fame,
    2011
are you getting any errors in the app log?
you might need to get DR watson logs and CUCM detailed trace in order to find the root cause.
javalenc
if this helps, please rate
