True dial-peer redundancy
May 2nd, 2008
I had an issue where a CCM was hung. My H.323 gateway was configured to send calls to this CCM first. There was network connectivity but the CCM would not answer any h323 requests. The router did not try the other 3 servers in order of preference. Is there a fix for this issue?
Jaime Valencia Sun, 05/04/2008 - 20:03
do you have the h225 timeout configured under the voice class to do that??
javalenc
if this helps, please rate
