Time of Day Routing Off by 1 hour
May 2nd, 2008
I am having an issue with TOD routing..from what I can tell the time is shifted one hour if I test via the DNA. The Time Zone is set to DST for the partition. The CallManager's Timezone is also DST. I am running 5.1.3...are there any issues or bugs that I might be running into? I don't think this is related to the DST revision...
gogasca Mon, 05/05/2008 - 21:45
Mmm Last year I found CSCsh81747 which in fact TOD was affected because of DST patches in 4.x train but...5.1.x is different....
Could you please try to change the settings to “Originating Device”, to see if TOD works fine ?
I dont remember any report for 5.1(3) now but...its 22:42 here after 5 hrs P1 call
Give it a try and let us know please
Also include exact CCM version and a brief description of what you are doing?
Please remove DNA out of the picture
Thanks Joe!
joeharb Tue, 05/06/2008 - 04:54
I am going to attempt to test during normal conditions (not use DNA)..I will report back if the time is correct or not...it may be a bug in DNA....
System version:
Administration version:
BTW I had seen the bug you referred to..didn't think that was application as well...
Thanks for the post..
metuzuner Wed, 06/24/2009 - 03:52
Experiencing the same problem on
During TOD routing testing; DNA returns different results than the testing that involved placing actual calls. DNA results are based on a time that's one hour off.
TAC can't figure out why. Definetely a problem with DNA though.
