Packet Capture between WAE's
May 2nd, 2008
  • Bronze, 100 points or more
I may be looking into this to much and I know the WAE's are doing things to speed the transfers but during FTP transfers between my sites I'm seeing alot of "TCP Retransmission" and "TCP DUP ACK". I don't see this on the LAN side after optimization so this might be normal...is it?
Mike
Zach Seils Sun, 05/04/2008 - 09:01
  • Cisco Employee,
Mike,
Are you taking the packet captures from the WAEs? If so, what you're seeing is likely the packet capture analysis getting confused due to the L3/L4 transparency (it's treating the original/optimized connections as a single connection).
Zach
mike-greene Mon, 05/05/2008 - 10:19
Zach,
My WAE's sit inline with our firewalls on the outside. So on the inline group.. Wan0 connects to a switch facing a router and the Lan0 has a cross-over cable between Lan0 and the outside interface of a PIX. I'm doing the 1st packet capture by spanning the Wan0 switch port...this is where I see the DUP ACK's and Retranmissions. I'm also doing a packet capture behind the firewall by spanning the PIX inside interface.
Zach Seils Mon, 05/05/2008 - 21:12
  • Cisco Employee,
Mike,
If you're only looking at one side or the other, then you are likely seeing true retransmissions. Is there any indication of packet loss (interface errors, etc.)?
Zach
