RDBMS sync
Answered Question
May 2nd, 2008
I am trying to do two things:
1. I would like to delete a particular user using this method and
2. I would like to move a user from one group to another.
I have attached what I thought was the proper way to delete a user from ACS, but apparently, it is not.
What am I doing wrong?
Dwane
Correct Answer by Jagdeep Gambhir about 8 years 11 months ago
Please use the attached file to remove and change user group,
First entry is to delete user
Second entry is to change group
It works fine
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Fri, 05/02/2008 - 11:58
  • Red, 2250 points or more
It works fine
~JG
