cnf-files
May 2nd, 2008
I'm trying to configure a new CME.
every time i load a firmware to cisco 7960 and try to create a cnf it gives this message:
pbx(config)#tftp-server flash:P00307020200.loads
pbx(config)#tftp-server flash:P00307020200.bin
pbx(config)#tftp-server flash:P00307020200.sbn
pbx(config)#telephony-service
pbx(config-telephony)#load 7960-7940 P00307020200
pbx(config-telephony)#create cnf-files
Post-init cnf creation is in progress, pls re-issue this command later
Any idea how to solve this problem?
Overall Rating: 5 (5 ratings)
Pari Thiagasundaram Fri, 05/02/2008 - 10:38
  • Silver, 250 points or more
Can you verify IP source address and port are configured? Along with max-dns?
The warning message means that you are trying to modify cnf related CLIs while cnf is under construction. Have you tried the command after the "post-init" process has completed the cnf-file construction ?
It looks like a configuration issue to me.
valides007 Fri, 05/02/2008 - 11:01
well this is what i did.
I already have a running CME. So i copied the configuration from this unit and paste it in the new CME. Everything seems working fine except the CNF creation.
I have tried the command many times. It seems that the post-init is still in process.
Archant IS Thu, 07/10/2008 - 02:34
Did you find a fix for this as i have same situation.
Thanks.
Ayodeji Okanlawon Thu, 07/10/2008 - 03:40
  • Cisco Designated VIP,
    2017 IP Telephony
I have seen this before. The cme router seems to be stucked in creating the configuration files for the 7960 phones.
If after a while, you still get this prompt, reload the router and you will be fine
Archant IS Fri, 07/11/2008 - 00:02
Hello, ive reloaded several times now, it definately seems stuck. Do you meen wipe and start again?
Ayodeji Okanlawon Fri, 07/11/2008 - 00:39
    2017 IP Telephony
can you issue this command on your ccme router...
show telephony-service tftp-bindings
if you hsve configuration files already created for your phones...use the more system command to view the file...
eg if you have a 7960, you should have an output like this from the show telephony-service tftp-bindings
tftp-server system:/its/SEPDEFAULT.cnf
tftp-server system:/its/SEPDEFAULT.cnf alias SEPDefault.cnf
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP000DBDBEF372.cnf.xml (this represent mac addy of a phone)
to view this file and its content..use the command
more system:/its/XMLDefault7960.cnf.xml
this will help you to see the configuration files.
Archant IS Fri, 07/11/2008 - 01:45
Hello, show telephony-service tftp-bindings doesnt return anything i'm afarid.
Thanks.
Ayodeji Okanlawon Fri, 07/11/2008 - 02:08
    2017 IP Telephony
That means that the router ha not created any configuration files.
May be you should start all over gain, erasing the files in the flash....this may be a long short..
Archant IS Sat, 07/12/2008 - 10:55
Fixed, didnt have ip source-address ... port 2000 in my telephony-service
m_chernogorsky Fri, 08/08/2008 - 11:43
I found solutions.
1. configure max-dn, max-ephone
2. configure time (clock set or ntp)
3. ip source-add port
4. load and create cnf
Maybe not all this step is required, but its work.
Thanks ^-)
MasterRu Tue, 03/20/2012 - 12:08
I had this error and did the following to resolve it:
  1. Create tftp-server commands with alias
    • tftp-server flash:/phone/7940/P00308010200.loads alias P00308010200.loads
    • ..... other tftp-server loads as well, noting the alias
  2. Set tftp-server source address
    • ip tftp source-interface
  3. Put the following commands under telephony-service
    • telephony-service
    • max-ephones
    • max-dn
    • ip source-address
    • cnf-file location flash:
    • load
    • create cnf-files
    After this, you should be able to configure your ephone and ephone-dn and watch the phones register.  If you enable debug ephone registration and debug tftp events, you can watch it all happen.
