Controller configuration for AP1242 with single antenna connection
May 2nd, 2008
I'm deploying a LWAPP solution over a MobileAccess distributed antenna system (DAS) using AP1242s. the A & B/G antennas are connected to the primary (right side) antenna outputs. The 4404 WLC (wireless->access points->radios->802.11a/n or 802.11b/g/n) has the AP configured with diversity enabled. The AP are installed on shelves in stacks of 4, with very little spacing between the the APs. My question is do I need to set the "diversity" setting to right? If so, what is the easiest way to do that through WCS?
Todd
Scott Fella Sun, 05/04/2008 - 09:38
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You can create an AP template and push it out the the ap's that need that confgiuration. If you don't have that many, might as well do it from the WLC.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
