Maintenance image version FWSM ?
May 2nd, 2008
HI,
How to check the Maintenance image version in a FWSM? DO I have to login in the boot mode?
I am going to upgrade the FWSM but looks like I have to upgrade the Maintenance image first.
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Fri, 05/02/2008 - 13:30
Refer to Checking the Maintenance Software section in this link
http://www.cisco.com/en/US/docs/security/fwsm/fwsm31/upgrade/guide/fwsm31up.html
Step 2 ..To boot the FWSM into the maintenance partition, enter the command for your operating system at the switch prompt:
•For Cisco IOS, enter the following command:
Router# hw-module module mod_num reset cf:1
•For Catalyst operating system software, enter the following command:
Console> (enable) reset mod_num cf:1
