IDS-4260 SNMP TRAPS SUPPORT....
May 2nd, 2008
I received the following traps while disconnecting the fiber from the IDS:
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (97610796) 11 days,
7:08:27.96
SNMPv2-MIB::snmpTrapOID.0 = OID:
SNMPv2-SMI::enterprises.9.9.138.2.0.1
SNMPv2-SMI::enterprises.9.9.138.1.3.3.1.3 = Gauge32: 4
SNMPv2-SMI::enterprises.9.9.138.1.3.3.1.4 = Gauge32: 3
SNMPv2-SMI::enterprises.9.9.138.1.3.3.1.5 = INTEGER: 4
SNMPv2-SMI::enterprises.9.9.138.1.3.3.1.6 = Gauge32: 97610796
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (97611029) 11 days,
7:08:30.29
SNMPv2-SMI::enterprises.9.9.138.1.3.3.1.4 = Gauge32: 1
SNMPv2-SMI::enterprises.9.9.138.1.3.3.1.6 = Gauge32: 97611029
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (97611229) 11 days,
7:08:32.29
SNMPv2-SMI::enterprises.9.9.138.1.3.3.1.4 = Gauge32: 2
SNMPv2-SMI::enterprises.9.9.138.1.3.3.1.6 = Gauge32: 97611229
I am not being able to decode the message using de CIDS-MIB, does anybody know what else do I need???
jreekers Sat, 05/03/2008 - 07:20
Hi Javier,
This should help:
http://jaguar.ir.miami.edu/~marcus/snmptrans.html
replace: "SNMPv2-SMI::enterprises" in any of these objects with ".1.3.6.1.4.1" and you'll be able to see what that trap is. For instance, let's look at:
SNMPv2-SMI::enterprises.9.9.138.1.3.3.1.3=Gauge32:4
I'll go to the OID translator, and in the "Object Identifier or Object Name" field, I put in:
.1.3.6.1.4.1.9.9.138.1.3.3.1.3
and it returns the following:
ceAlarmHistEntPhysicalIndex OBJECT-TYPE
-- FROM CISCO-ENTITY-ALARM-MIB
-- TEXTUAL CONVENTION PhysicalIndex
SYNTAX Integer (1..2147483647)
MAX-ACCESS read-only
STATUS Current
DESCRIPTION "This object specifies the physical entity that generated
the alarm."
::= { iso(1) org(3) dod(6) internet(1) private(4) enterprises(1) cisco(9) ciscoMgmt(9) ciscoEntityAlarmMIB(138) ciscoEntityAlarmMIBObjects(1) ceAlarmHistory(3) ceAlarmHistTable(3) ceAlarmHistEntry(1) 3 }
Anyway, you can look up each of those in the same way.
These are all part of the CISCO-ENTITY-ALARM-MIB
-Joe
javiercastro Tue, 05/06/2008 - 06:49
It seems to be that the NMS is not being able to decode the trap properly. Is there any way to enable the usual LinkUP/LinkDown traps for the sensing interfaces of a IDS-4200 v6.0? That's what the trap I posted was about.
Many thanks,
