Cisco 2610 VPN Server / VPN Client problem / Port Range Forward
May 2nd, 2008
Hello! I have a 2610 with the attached configuration, show int, show ver, etc...
I tried to setup a VPN, and it authenticates and connects, but I can only ping the server (access lists? routing tables).
My other problem is that when I try to connect to my business VPN, it acts the same way (that is, I connect to the VPN and it authenticates, but I can't access anything)
I have Embarq DSL, and I tried hooking directly into the DSL modem and giving the business laptop the external IP to see if it was the DSL box, and it worked fine, so there is a problem in my router configuration.
Also, does anyone know how to do a port range forward in IOS?
--scott
positive1 Mon, 05/05/2008 - 01:49
This was working for me (port forward isue)
ip nat pool sip 192.168.1.200 192.168.1.200 netmask 255.255.255.0 type rotary
ip nat inside destination list 100 pool sip
For VPN: Do you have route for network youo tried to reach?
ip route x.x.x.x x.x.x.x next hop/outside interface (x.x.x.x is private IP of remote network)
