Reg Output drops on Gig interface
May 2nd, 2008
Dear All,
I have core 6509 switch in our data center connecting to 7206 router with gig interface both the sides. I am observing output drops occuring on switch end and the drops are not occuring continuesly, its happening intermetently.
Both the sides are full duplex and speed 100 is configured and at the same time router end interface was not dropping packets.
GigabitEthernet7/36 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0015.fa02.268f (bia 0015.fa02.268f)
Description: ***************
MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
reliability 255/255, txload 53/255, rxload 22/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is on
Clock mode is auto
Last input never, output 00:00:57, output hang never
Last clearing of "show interface" counters 00:00:06
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 693
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 8883000 bits/sec, 5492 packets/sec
5 minute output rate 20941000 bits/sec, 5471 packets/sec
25985 packets input, 5001283 bytes, 0 no buffer
Received 4 broadcasts (4 multicasts)
0 watchdog, 0 multicast, 0 pause input
24942 packets output, 10994588 bytes, 0 underruns
#sh int g7/36 | inc flush
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 188
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 1362
Above are the logs caputred during packet drops. Kindly advise what are the possibilites for dropping packets.
Gopal
Overall Rating: 3.8 (5 ratings)
cisco_lad2004 Sat, 05/03/2008 - 00:43
  • Gold, 750 points or more
Typically output drops occurs when line is congested. it does not seem to be the case here.
your load is 20% and running full duplex.
1-what is the load on adjacent interface ?
2-turn off ur flow control. "(config-if)#flowcontrol send off
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml#drops
Sam
Giuseppe Larosa Sat, 05/03/2008 - 00:53
  • Hall of Fame,
    Founding Member
I see that output flow-control is on, so I wonder if it could be the c7206 sending IEEE pause frame to cause the small output drops you see.
Otherwise, you have to look at what type of linecard you have: you could experience performance troubles on older 48GE linecards where groups of n ports share the same cpu/resources and connection to the backplane is only 8Gbps.
there has been another thread about this.
hope to help
Giuseppe
gopal_4476 Sat, 05/03/2008 - 01:14
Dear Giuseppe,
How do i check which line card is being used.
Gopal
mounir.mohamed Sat, 05/03/2008 - 01:17
Cat6k#show module
Please rate helpful posts.
Best Regards,
Mounir Mohamed
mounir.mohamed Sat, 05/03/2008 - 01:06
Total output drops counter increased because the output queue is full, a common cause of this might be traffic from a high bandwidth link being switched to a lower bandwidth link or traffic from multiple inbound links being switched to a single outbound link
For example if there is a group of FE 100 interfaces connected to Data Center Servers trying to send traffic behind your router (7206) the output queue may get full which is cause the output drops counter to be increased
So start monitoring input traffic from your router or even the output traffic pattern on the Catalyst interface (G7/36) so it's bandwidth problem you have to change the port speed from BOTH sides to be 1000 instead of 100
Note that the interface output queue doesn't change if the speed increased, but the switch will be able to switch frames fastly with line rate 1000 instead of 100
Also in your case flow-control might be the cause of the problem.
The below URL for Troubleshooting Switch Port and Interface Problems:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfd6.shtml#giga
Best Regards,
Mounir Mohamed
gopal_4476 Sat, 05/03/2008 - 01:23
CEF720 48 port 10/100/1000mb Ethernet - is the module being used in our switch.
Gopal
cisco_lad2004 Sat, 05/03/2008 - 01:33
Gopal
The problem is very likely flow control, are u able to disable it and test ?
Sam
gopal_4476 Sat, 05/03/2008 - 02:38
Hi Sam,
Could you provide me some links to get more clarity why flow control is causing this issue. Using that only i can change the config on the core boxes.
Gopal
cisco_lad2004 Sat, 05/03/2008 - 03:05
Hi Gopal
Pay special attention to the fact that if u need predictable results u need to follow guidelines below.
How is other end configured, flow control receive off?
Flow control can be useful, but from my own experience I have learn to remove it. I am using WS-X6724-SFP on 7600 chassis.
Sam
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2ZY/command/reference/I1.html#wp1084927
To obtain predictable results, follow these guidelines:
•Use send on only when remote ports are set to receive on or receive desired.
•Use send off only when remote ports are set to receive off or receive desired.
•Use receive on only when remote ports are set to send on or send desired.
gopal_4476 Sat, 05/03/2008 - 04:00
Hi Sam,
Router end gig port is configured for flow control ON.
GigabitEthernet0/0 is up, line protocol is up
Hardware is BCM1125 Internal MAC, address is 0016.9de5.4810 (bia 0016.9de5.4810)
Internet address is 10.223.252.129/29
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 6/255, rxload 10/255
Full-duplex, 100Mb/s, media type is RJ45
output flow-control is XON, input flow-control is XON
Last input 00:00:02, output 00:00:00, output hang never
Last clearing of "show interface" counters 31w3d
30 second input rate 4187000 bits/sec, 1483 packets/sec
30 second output rate 2641000 bits/sec, 1415 packets/sec
rseiler Fri, 09/12/2008 - 01:05
  • Silver, 250 points or more
What is the type of linecard that is reporting the output drops? Send a show mod from the switch.
