CCNP Questions (2) on BGP
May 3rd, 2008
I read the CCNP BSCI Official Certification Guide and I believe that the book contains errata in 2 topics in BGP (actual book questions).
1. A route has an AS-Path of 7 25 19 69. What can you learn from reading this path?
a. The local AS is 7.
b. The origin AS is 69.
c. There is a loop
d. 7 is the origin
Although i believe that a) is correct, in the Answers section of the book b) appears as the right answer. Anyone can tell me why?
2. Consider the following route map. What will be the local-preference for 192.168.25.0/24?
access-list 39 permit 192.168.24.0 0.0.3.255
access-list 32 permit 192.168.26.0 0.0.0.255
route-map test permit 10
match ip address 39
match ip address 32
set ip local preference 150
route-map test permit 20
match ip address 39 32
set ip local preference 200
a.0
b.100
c.150
d.200
Again I believe that the correct answer is d) but in the Answers section of the book c) appears as the right answer. Anyone can tell me why?
Istvan_Rabai Sat, 05/03/2008 - 02:38
  • Gold, 750 points or more
Hi Georgios,
For question 1:
b. is the right answer. As BGP routers pass routes from AS to AS they append their AS number to the AS path attribute.
So the first AS where the route originated was AS 69. The last AS the route left was AS 7 when it arrived to the local AS.
For question 2.
The right answer is d. because of the following:
Obviously, 192.168.25.0/24 will match only acl 39.
In the route map this acl appears twice:
Route-map entry 10:
is true if "match ip address 39" AND "match ip address 32" is true.
Route-map entry 20:
is true if "match ip address 39" OR "match ip address 32" is true.
This is why Route-map entry 20 will be true and its "set ip local preference 200" command will be executed.
The rule here is:
match x
match y ----------- match x AND match y AND match z
match z
match x y z ------ match x OR match y OR match z
Cheers:
Istvan
