HSRP Over interface Tunnel
May 3rd, 2008
Hi.i have little problem.i have two 7606 wan edge routers.this two routers connect to wan routers over wan network.i have to configure tunnel interface for wan routers and 7606 routers becouse my wan conectivity in this way is provided with Vsat network.so h want to make this tunnel connection high available.so without any hsrp my tunnel source on 7606 side is one of my gig 1/4 ethernet interface that connects my 7606 to vsat modem and tunnel destination is gig 0/0 of wan router that is connected to vsat modem too.so is there any way that i configute hasrp on my gig ethernet on 7606 side and use high available ip address as a source of my tunnel interface on 7606 side (now tunnel source is gig 1/4)?? thanks...
paolo bevilacqua Sat, 05/03/2008 - 08:31
  • Hall of Fame,
    Founding Member
Hi, have to say that the punctuation-free description doesn't allow an easy understating of the topology, a diagram would do that better, so consider including one to let people be able to help you.
