1861 CUE 3.0.3 Update
May 4th, 2008
For the UC500 you can get the new 4.2.7 software which includes the CUE 3.0.3 update. Where do I get the update for the Cisco 1861 Router? Where do I get the CUE language files for the 1861 Router?
kbrinkmann Sun, 05/04/2008 - 21:58
Hi Rob,
are you sure that these files also work for the 1861 Router? The 1861 and UC500 ships with a special version of the CUE. I tried to install the "standard" files on a UC500, but it does not work.
I have to do a clean install, but if this does not work I do not have a fallback option.
Klaus
kbrinkmann Mon, 05/05/2008 - 06:38
Hi Rob,
but these files only work un the UC500. You need a different version for the 1861.
Klaus
paolo bevilacqua Mon, 05/05/2008 - 07:36
  • Hall of Fame,
    Founding Member
this is a bit confusing. I haven't tried that myself, but you say the "regualar cue" files don't work (why? what happens?), neither the ones for UC500.
That would imply a third set files would be needed, but I'm not aware that these exists.
Either some mistake by cisco, or some other problem ?
kbrinkmann Mon, 05/05/2008 - 22:57
I tried a clean install using boot helper. The 3.0.3 update files for the UC500 do now work on the Cisco 1861 Router.
A vew weeks ago I tried to install the old CUE files (2.3.4) for the UC500 on the 1861 with an error.
Thanks.
Klaus
Rob Huffman Mon, 05/05/2008 - 07:36
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Klaus,
Sorry, I thought you were looking for the UC520 Files (guess I can't read to well today)
All other CUE Files (NME,NM-CUE and AIM-CUE) are on the first link I sent;
http://www.cisco.com/kobayashi/sw-center/voice/cue/303.shtml
Hope this helps!
Rob
kbrinkmann Mon, 05/05/2008 - 22:58
Hi Rob,
I tried a clean install with boot helper.
Thanks.
Klaus
