Connecting 2 2621XM with two modems as a backup
May 4th, 2008
Hi all,
Am facing a little confusion.
Here the point :
I have 2 2621XM with 2 WIC 2 A/S to connect using a LL and 2 modems. this connection is just a backup to an existing E1 link.
Is it necessary to configure my serial interfaces on async mode ?
First i used 2 SS-RS232 DCE cables but it does nt work, the interface is continuosly on reset status. I think I need DTE cables, is it true ?
Thanks for ur assistance.
Best Regards
Paolo Bevilacqua Sun, 05/04/2008 - 09:39
  • Hall of Fame,
    Founding Member
Yes, you need DTE cables to connect the modems. sync or async depends on the type of the modem.
kaliga2008 Sun, 05/04/2008 - 12:51
Thanks for the precision. Am waiting the delivery of these cables.
what dp u mean by it depends on the type of the modem?
Thanks for ur help.
Paolo Bevilacqua Sun, 05/04/2008 - 15:21
  • Hall of Fame,
    Founding Member
Type of modem, sync or asynch ?
