cjrchoi11 Sun, 05/04/2008 - 16:25
Is it not impact Unity connection if I upgrade same way to other CUCM platform? I taught there is different code since it contains unity connection.
Thanks in advance,
Rob Huffman Sun, 05/04/2008 - 18:36
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Jaime Valencia Sun, 05/04/2008 - 19:27
  • Cisco Employee,
  • Hall of Fame,
    2011
Upgrading from Cisco Unified Communications Manager Release 6.0(1) to Release 6.1(1a) Using the UCSInstall File
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/rel_notes/6_1_1/cucmbe-rel_note-611a.html#wp291021
Upgrading from Cisco Unity Connection 2.0 to 2.1 or Cisco Unified CMBE 6.0 to 6.1
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/rel_notes/6_1_1/211ucrn_be.html#wp48891
there will be some documentation for 6.1(2) on the same
javalenc
if this helps, please rate
cjrchoi11 Mon, 05/05/2008 - 05:37
I want to make clear to not impact the production. please clarify the following,
1. upgrade CUCM part=download CUCM image and upgrade from 'Cisco Unified OS administration' menu
2. upgrade CUCM unity connection part=download Unity connection image and upgrade from 'Cisco Unified OS administration' which is same menu to upgrade the CUCM image.
-->Eventually I need two times upgrading to upgrade CUCM and unity connection both. Am I corrrect?
-->if the above assumption correct, I guess CUCM-BE has two independent partition to running CUCM and Unity connection seperately but provides single interface to manage together.
Thanks in advance,
John
