vlan filter doesn't filter L2 traffic
May 4th, 2008
Calalyst 3650 (IOS 12.2(25)SEE2) as a L2 switch.
I want to block all L2 traffic between two MAC addresses.
One MAC is a IP-Phone and the other MAC is the local Voice Gateway. IP-Phone and Voice-Gateway are both in VLAN 10. Both MACs are attached via VLAN Trunks:
interface FastEthernet0/34
description IP-Phone
switchport access vlan 50
switchport mode access
switchport nonegotiate
switchport voice vlan 10
mls qos trust dscp
spanning-tree portfast
interface GigabitEthernet0/1
description Voice-Gateway
switchport trunk native vlan 10
switchport mode trunk
MAC addresses are taken from mac-address-table and double-checked;-)
I set up a VLAN filter as described in:
sw05(config)#mac access-list extended srst
sw05(config-ext-macl)#permit host 0090.0b08.0507 host 001a.2f80.33cd
sw05(config)#vlan access-map block-srst
sw05(config-access-map)#action drop
sw05(config-access-map)#match mac address srst
sw05(config)#vlan access-map block-srst 20
sw05(config-access-map)#action forward
sw05(config)#do sh vlan access-map
Vlan access-map "block-srst" 10
Match clauses:
mac address: srst
Vlan access-map "block-srst" 20
Match clauses:
sw05(config)#vlan filter block-srst vlan-list 10
But this filter doesn't work.
Do you have any ideas?
pwellmann Sun, 05/04/2008 - 13:12
It works!
You only have to ad a second entry in the ACL and pay a little patience.
I have modified the ACL for matching both directions:
permit host 001a.2f80.33cd host 0090.0b08.0507
You have to save the configuration (wr) and wait for approx. 5 minutes. Then it works. Clearing the mac-address-table may help...
