CCM6 configuration backup
May 4th, 2008
Hello, i have a ccm version 6 and i want to save the configuration. I saw that the backup use a sftp server. I want to save the config on ly computer. Do i have to insall a ssh server? what server can you suggest to install? OR can i simply download config files (that i don't know the name) by tftp as a switch?
Jaime Valencia Sun, 05/04/2008 - 19:50
use freeFTPd, that's really easy to config and has proven some of the best results, you can install it on your PC
the rest of the config is done using the DRS on the server.
javalenc
if this helps, please rate
