Rollover connection
May 4th, 2008
Hello
I would like to ask which application I can use from a notebook to a router if i use a rollover connection for console.
Basically my situation is as follows:
I have an IBM T43 Thinkpad. It has no DB-9 connection. It has an LPT, network, wifi, modem & USB connections.
I need to connect to routers and switches console port to configure and do troubleshooting on the routers and switches. I know a rollover cable can be used to connect to switch & router consoles. But I need to plug the other end into my notebook. I am not sure if it is a good idea to plug the other end into the ethernet port as that doesn't make sense to me to do something like that.
Will i have to get a notebook with a DB-9 connection? Or is there a way around this problem other than having to buy a converter adapter?
Many Thanks
willemvw
willemvwyk Sun, 05/04/2008 - 14:06
Hi Sam
Thank you for the response :)
I just want clarification. Do I understand you correctly if I say I can plug the one end of my rollover cable into my ethernet port and the other end into my cisco console port?
Please bear in mind (as I mentioned above) I have no COMx port on my thinkpad. So I cannot use DB-9 connectors.
JORGE RODRIGUEZ Sun, 05/04/2008 - 14:52
  • Green, 3000 points or more
It is correct that you can use a rollover cable but in your case you do not have a COM port, you need a USB to RS232 converter cable, you can use this on any USB port that is version 1 or 2 complient. On the RS232 end you then can use the regular cisco console cable.
http://www.emtcompany.com/products/adapters/dxubdb9-usb-to-serial-db9-adapter-cable.htm?gclid=CJmhzI72jZMCFRCCGgodtGKBgA
paolo bevilacqua Sun, 05/04/2008 - 15:23
  • Hall of Fame,
    Founding Member
Hi, just get an USB to serial adapter, or a PC card with serial connection.
When working on cisco products, you cannot do without a serial port.
Richard Burts Sun, 05/04/2008 - 18:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
willemvw
Just to emphasize the previous responses - do NOT plug your rollover cable into your Ethernet interface. Ethernet will certainly not work for this. What you need is a converter for USB to serial/COM. There are several of them that are available.
Rick
