Remote control application via meetingplace express
May 4th, 2008
Does the latest version of meetingplace express support remote control so that one user can remotly control the application of the other user ?
Is it the same application that Cisco TAC use to remote control my telnet or console session during the TAC cases ?
Mohamed
Overall Rating: 5 (1 ratings)
moabdallah Sun, 05/11/2008 - 06:31
Hi Oliver,
Thanks for your reply
What is the different between this feature on meetingplace express and Webex ?
Do i need the webex to offer remote support to my customer ?
Mohamed
okuehn Mon, 05/12/2008 - 22:11
  • Bronze, 100 points or more
Hi Mohamed,
as far as i know these are totaly different products. cisco acquired webex in 2007 and added it to their product portfolio. i think the key difference is that webex is a hosted solution while meetingplace is installed on a server in your company.
however, if you have meetingplace installed at your site, you can use the remote control features out of the box - without using webex additionally.
regards, oliver
ricardorojas123 Wed, 05/14/2008 - 05:34
Hi I have Cisco Meeting Place Version: 2.0.2.40, and how I request the control of a Shared Screen?
okuehn Wed, 05/14/2008 - 10:58
As a moderator or presenter, you can request control of the screen of another presenter or moderator.
Procedure:
Step 1 Click Request Control on the Share tool control strip.
If the request is accepted, a message informs you that you have been granted control of the screen. The Request Control button becomes a Release Control button. You can now take control of the shared screen.
Step 2 To return control of the shared screen to the original presenter, click Release Control on the Share tool control strip.
regards, oliver
