05-04-2008 05:46 PM
Hi All,
Had the CiscoWorks server crash over the weekend, someone kicked the power cable out of the server. And am now seeing a problem with the RME Database.
When ever I try and connect to any pages that displays data from the database i get the following error:
HOME0002: Could not get database connection. Make sure that RME DB server is running. Check RMEHome.log for more details.
I have also noticed that I am no longer able to view device details through "devcie centre". I can see the "groups" the devices would belong to but not the devices under, when I expand "All Devices" there is nothing. Hopwever when I look at the discovery log I can see all my devices being discovered.
Any help would be greatly apprectaed.
Its LMS 3.0.1 on Win 2K3
Jason
05-04-2008 05:48 PM
05-04-2008 06:24 PM
I'll bet if you shutdown dmgtd, you'll see an rmeng.log file in NMSROOT\databases\rmeng. If so, delete this file, then run:
NMSROOT\objects\db\win32\dbsrv9 -f NMSROOT\databases\rmeng\rmeng.db
After that, you should be able to restart dmgtd, and have RME work again.
05-04-2008 07:36 PM
When I stop the dmgtd process, the file rmeng.log is deleted.
I have run the command you mentioned but still no joy, same error messages..
05-04-2008 08:22 PM
Please post the output of the pdshow command.
05-05-2008 10:48 PM
05-06-2008 09:30 AM
Everything points to a problem with the ACS integration, and not the database. Assuming you're using HTTP for the ACS protocol, it would be really helpful to see a sniffer trace of TCP traffic between LMS and ACS when you get this error.
If you are using HTTPS, then you should open a TAC service request to get the steps to enable ACS integration debugging.
09-13-2010 11:46 AM
09-13-2010 04:52 PM
Start a new thread for your issue.
