CME COR block internal
study_voip
is there anyway to block internal calls on CME? like two extensions, 101, 102, I don't want 101 call 102
other question, I have one 2600 router (CME), I have another 2800 router (with CUE), can 2600 CME use CUE on 2800 via IP?
thanks
7 Replies 7
paolo bevilacqua
Yes, or you can simply prevent calling 102 from 101 with a translation-profile and rule
rule 1 reject /^102/
applied incoming to dn 101
And yes, you can do that with the CUE.
rate first, will verify later, thanks
Have you ever tried yourself, regardless how I configured the translation and applied incoming/outgoing, the call can not be blocked
This is known to work, post your configuration an exact IOS used.
thanks
I got it working with translating /102 /9999/
however, did not work with reject /102
thanks again
will try 2600CME----IP----2800CUE
Ok, Watch out that if you don't configure as ^102, calls to any number that contains 102, will fail.
