05-04-2008 08:41 PM - edited 03-05-2019 10:45 PM
Can someone take a look at my route-map, Its not forcing the "default-information originate" route out of e0 and it seems like the default route is advertised through both e0 and s0.
Core1
interface Ethernet0
ip address 10.100.10.17 255.255.255.248
ip ospf network point-to-point
interface Serial0
ip address 10.100.10.2 255.255.255.248
ip ospf cost 10
clock rate 4000000
router ospf 1
router-id 1.1.10.1
log-adjacency-changes
passive-interface default
no passive-interface Ethernet0
no passive-interface Serial0
network 10.100.10.2 0.0.0.0 area 0
network 10.100.10.17 0.0.0.0 area 0
default-information originate route-map DEFAULT
access-list 10 permit 10.100.10.16 0.0.0.7 log
route-map DEFAULT permit 10
match ip address 10
match interface Ethernet0
set metric 1
set metric-type type-1
set interface Ethernet0
Core2
interface Ethernet0
ip address 10.100.10.25 255.255.255.248
interface Serial0
ip address 10.100.10.3 255.255.255.248
ip ospf cost 10
interface Serial1
ip address 10.100.10.33 255.255.255.248
clock rate 4000000
router ospf 1
router-id 1.1.10.2
no passive-interface Serial1
network 10.100.10.3 0.0.0.0 area 0
network 10.100.10.25 0.0.0.0 area 0
network 10.100.10.33 0.0.0.0 area 0
QA_1 - show ip route
10.0.0.0/8 is variably subnetted, 11 subnets, 3 masks
C 10.40.40.0/24 is directly connected, Loopback4
O E1 10.30.0.0/16 [110/94] via 10.100.10.33, 00:25:26, Serial1
O 10.40.0.0/16 is a summary, 03:39:32, Null0
C 10.40.10.0/24 is directly connected, Loopback1
O E1 10.60.0.0/16 [110/94] via 10.100.10.33, 00:25:26, Serial1
C 10.40.20.0/24 is directly connected, Loopback2
C 10.40.30.0/24 is directly connected, Loopback3
C 10.100.10.32/29 is directly connected, Serial1
O 10.100.10.0/29 [110/74] via 10.100.10.33, 00:25:27, Serial1
O 10.100.10.16/29 [110/84] via 10.100.10.33, 00:25:27, Serial1
O 10.100.10.24/29 [110/74] via 10.100.10.33, 00:25:27, Serial1
O*E1 0.0.0.0/0 [110/75] via 10.100.10.33, 00:25:27, Serial1
Looking at QA_1, default route should be advertised as 85 not 75, meaning if it goes through core1(e0)->finance_1(e0/1)->finance_1(e0/0-> Core2(s1) then it should be 85 but it seems like the route-map isn't working on Core1 and the default route is being advertised over the Core1(s0), cost of Core2(s1) is 64.
Anyone?
05-05-2008 12:58 AM
the "default-information originate route-map" command will insert a default route into the OSPF database based on some criteria. The external LSA containing the 0.0.0.0/0 is then flooded throughout the area and each router will calculate the best path based on all link metrics. You cannot force a default route "out through" an interface in OSPF. The only way to get a different path installed is to change some link metrics. But be aware, this will affect all routes and without further information I do not know, which effects this has in your network.
Basically, by using "ip ospf cost 10" on Serial0 you make both, S0 and E0 equal cost pathes despite they are of different bandwidth. Removing the "ip ospf cost 10" and placing a "bandwidth X" command under Serial0, where X reflects the real bandwidth, might solve the issue. Please only do so with due care and consideration of all routes affected.
Hope this helps! Please use the rating system.
Regards, Martin
05-05-2008 06:28 AM
Thanks for the response, I'm trying to understand the exact logic that is happening here.
Originating a default-route using this method, is there anyway I can advertise the metric of 1 out of interface e0 and metric of 5 out of serial1? Is there anyway to tweak this in the route-map?
I'm trying to do something like this...
According to the diagram, If connected route between Core1(e0) and Finance_1(e0/1) exists then advertise metric of 1 to Finance_1 and advertise metric of 5 to everyone else.
Is this possible?
05-06-2008 03:25 AM
as Martin has clearly explained you are dealing with OSPF ,a Link State IGP and you wish it to behave like a Distance Vector Protocol (like offset-list in RIP) and this is not possible.
The route-map can be used to define under what conditions a type 5 LSA for net 0.0.0.0/0 should be created and sent out in the OSPF domain (that is LSA flooding). By using type 1 external metric every router will calculate the cost to the default route :
E1 metric inside the LSA itself + OSPF cost to reach the LSA originator (=ASBR) node.
If there are two ASBRs injecting an E1 default and given the ospf links in the topology (native costs or modified) each ASBR will have its own region of influence, where the other OSPF nodes will choice to send packets matching the default route to one of them. For some topologies and costs you can have some nodes to install two default routes one to every ASBR if the total costs are equal from their point of view.
This is how OSPF works for its link state nature. You can only play on ospf link costs with the ip ospf cost or the bandwidth command in order to influence the choice that every node makes. An LSA is a data structure that is sent unchanged out of all interfaces inside OSPF packets. This is a requirement because all nodes within an area must have the same database (LS DB).
Best Regards
Giuseppe
05-07-2008 07:36 PM
I figured out a way to make it work. What I am doing is originating a default route and tagging(for ex. with tag 1) it in a route map. Then on the other router, I apply a filter on incomming tagged routes (match tag 1) and then I set a low metric. So Router 1 tags 1 and Router 2 tags 5.
The preferred router utlizes what ever default route it wants.
