CME/CUE integration to MS Exchange server
May 5th, 2008
Could CME/CUE be integrated to MS Exchange server?
Overall Rating: 4 (1 ratings)
kelvin.blair Mon, 05/05/2008 - 11:30
Yes. CUE supports integrated messaging to an email server. Here is the link that shows you how to integrate CUE to an email server.
I've seen some post where people are getting Call Manager Express to work directly with Exchange 2007. I have not had any experience with that type of integration. If you are not running Exchange 2007, you can use stonevoice for your Unified Messaging needs with Call Manager Express.
jwaters24 Fri, 06/20/2008 - 09:26
I have setup email notification in CUE GUI and I can receive notification via IMAP, but not smtp.
I want the notification to go to my exchange account.
I set up smtp through the GUI with the exchange IP address and the authentication is my admin credientials.
The Domain is Does it need to be company.local instead?
Any suggestions?
Frank Vo Mon, 06/23/2008 - 01:27
The following debug in CUE might help troubleshoot this issue.
trace voicemail msgnotif all
show trace buffer tail
